Activity Forums Apple Final Cut Pro Legacy errors when transferring files from my 1TB sata to 500gig firewire800
  • errors when transferring files from my 1TB sata to 500gig firewire800
    Posted by Chris Baldwin on November 9, 2006 at 12:08 am
    Can large 35 gig files be moved from a sata drive to a firewire drive? They keep failing after about an hour of transferring and 34gigs. I can’t remember the exact error but it happens on multiple files so its not a corrupted file.
    For context these files are create in FCP using Export:QuickTime Reference Movie. I’ve made the movies self contained files but I didn’t check the option for recompress all frames. Could that be the issue?
    Chris Baldwin replied 19 years, 10 months ago 2 Members · 3 Replies
  • Chris Baldwin
    November 9, 2006 at 12:09 am
    It happened again and the error is (Error Code -1309)
  • Don Greening
    November 9, 2006 at 12:35 am
    [Chris Baldwin] “Can large 35 gig files be moved from a sata drive to a firewire drive?”
    I do this quite a bit after capturing footage with one computer then transferring the files over to another for editing. I haven’t transferred single files that are as big as yours but I’ve done several files in a batch where the total size was much more than 34 Gig. I was also using a combintation of extrnal SATA and FW drives, just like you’re doing.
    [Chris Baldwin] “I’ve made the movies self contained files but I didn’t check the option for recompress all frames.”
    I think that recompressing all frames simply tells FCP to re-render everything before it exports the file. If you’ve already done a render before export then you shouldn’t have to worry about it.
    Since I haven’t run into the problem you’re having I can’t offer specific recommendations on a fix, other than to suggest running something like DiskWarrior on your externals to make sure the directories on those drives are in top shape, then I’d try the transfer process again.
    – Don
    “Please take a moment to fill out your profile, including your computer system and relevant software. Help us help you.”
  • Chris Baldwin
    November 9, 2006 at 4:09 am
    I found burried in the back alleys of the internet that Hard drives that have been formatted as FAT32 (meaning they were once used connected to a PC) are then limited to file sizes of 4 gigs.
    {error -1309 fileBoundsErr: file’s EOF offset mark or size is too big}
    See this page for people who knew more about this than me…
    https://whirlpool.net.au/forum-replies-archive.cfm/560173.html
    Soooooooo some more research online leads me to our own Ken Stone’s expaination of this and how to format the drives correctly.
    https://www.kenstone.net/fcp_homepage/partitioning_tiger.html
    Thanks for the help!
