Activity Forums Adobe After Effects Expressions error with valueAtTime
  • error with valueAtTime
    Posted by Jamie Bradshaw on March 4, 2008 at 2:54 pm
    Am I going mad? Is there something wrong with this expression?
    x3 = thisComp.layer(“Null 1”).transform.position[0].valueAtTime(0);
    I keep getting an error saying that the function is undefined.
    Any help would be massively appreciated.
    Jamie
    Darby Edelen replied 18 years, 6 months ago 3 Members · 3 Replies
  • Dan Ebberts
    March 4, 2008 at 2:57 pm
    You need to put the array indexing at the end, like this:
    x3 = thisComp.layer(“Null 1”).transform.position.valueAtTime(0)[0];
    Dan
  • Jamie Bradshaw
    March 4, 2008 at 2:59 pm
    ah I see thanks a million Dan. 🙂
    Still a bit confused as to why it has that syntax. My way seems to make more sense, but who am I to argue! 🙂
  • Darby Edelen
    March 5, 2008 at 10:25 pm
    [Jamie Bradshaw] “Still a bit confused as to why it has that syntax”
    x3 = thisComp.layer("Null 1").transform.position[0].valueAtTime(0);
    In the above statement, thisComp.layer("Null 1").transform.position[0] evaluates to a float value which has no associated function valueAtTime().
    x3 = thisComp.layer("Null 1").transform.position.valueAtTime(0)[0];
    In the above statement thisComp.layer("Null 1").transform.position.valueAtTime(0) evaluates to the position property at a given time. A property has access to the valueAtTime() function because it is a method of the property class, where as a float value has no associated methods/functions.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
