Activity Forums Adobe After Effects Expressions Error with opacity expression
  • Error with opacity expression
    Posted by Justin Sarceno on March 15, 2019 at 11:49 pm
    Having an error with this opacity expression in CC2019:
    opacityEven = 50;
    opacityOdd = 100;
    f = timeToFrames();
    if (f%2 == 0) opacityEven else opacityOdd
    Message:
    After Effects warning: Expression Disabled
    Error at line 1 in property ‘Opacity’ of layer (‘xyz’) in comp
    ‘xyz’.
    Undefined value in expression (could be an out of range array subscript?)
    Justin Sarceno replied 7 years, 6 months ago 2 Members · 4 Replies
  • Dan Ebberts
    March 16, 2019 at 12:06 am
    That single-line if/else syntax won’t work with the new JavaScript engine. Try changing the last line to this:
    (f%2 == 0) ? opacityEven : opacityOdd
  • Justin Sarceno
    March 16, 2019 at 12:20 am
    Hi Dan, I tried that exact expression and got this error:
    ReferenceError: f is not defined
  • Dan Ebberts
    March 16, 2019 at 12:23 am
    Did you replace just the last line? The whole expression would be like this:
    opacityEven = 50;
    opacityOdd = 100;
    f = timeToFrames();
    Dan
  • Justin Sarceno
    March 16, 2019 at 4:28 am
    My bad, I just replaced the last line and it now works. Thank you so much!
