Activity Forums Adobe After Effects Error with .mov files
  • Error with .mov files
    Posted by Neil Carroll on April 14, 2008 at 5:10 pm
    I am having an issue with .mov files in After Effects CS3. I get an error saying that .mov files are not supported. They have been supported in past versions and I can’t imagine that Adobe would remove that support.
    Any suggestions?
    Neil
    Joeri Kassenaar replied 18 years, 4 months ago 4 Members · 8 Replies
  • 8 Replies
  • Neil Carroll
    April 14, 2008 at 5:49 pm
    The files are Cinema 4d renders. I have always output them in .mov format without any problems, but I can change if need be. I am more worried about opening past projects and having all my video references off line.
    I didn’t consider that it could have been quicktime causing the problem. It seemed to coincide with the installation of CS3. I’ll check it out.
    Thanks for the suggestion.
  • Kevin Camp
    April 14, 2008 at 7:51 pm
    there were issues with qt7.4 that were fixed with 7.4.1, although your problem does not match the issues i’ve heard about.
    there are also updates to ae that don’t come up in the adobe updater. you can download those from adobe’s ae download site, i think the current version is 8.0.2.
    the only other thing i can think of is what dave already mentioned… that you rendered to a codec that you don’t have installed anymore, or maybe isn’t compatible with your current version of quicktime. but if you rendered to lossless animation, that should work with just about any version of quicktime and is a standard codec that comes with quicktime on any platform….
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Roman Flute
    April 16, 2008 at 11:59 pm
    This has just happened to me starting about an hour ago. I was able to import this morning and now nothing. I am checking to make sure nobody has updated Quicktime or something. But I am trying to find a solution
    Roman Flute
    Motion Graphics/Multimedia Developer
    http://www.romanflute.com
    roman@romanflute.com
  • Neil Carroll
    April 17, 2008 at 12:27 pm
    Roman here is my update if it helps.
    With the update to After Effects and Quicktime I have been able to import newly created quicktime files into CS3, but existing ones are still a problem. However, these older files behave normally when I open an earlier CS2 version of the project.
    Neil
  • Roman Flute
    April 17, 2008 at 2:27 pm
    Yeah – I ended up backing up to an older version of QT. A new update had been put on it. Very Irritating. But up and running again!
    RF
    Roman Flute
  • Kevin Camp
    April 17, 2008 at 2:41 pm
    [Neil Carroll] “older files behave normally when I open an earlier CS2 version of the project”
    are you using an intel mac? i’m asking because it interesting that it works on ae7 but not ae8… ae7 is only powerpc and must run under rosetta (ppc emulation) on an intel mac, but cs3 is intel native. being intel native, it requires all effects and codecs to be intel native as well. so you may have (or have found) a problem with the codec used for your .mov files that is not working with your intel mac….
    if you do have an intel mac and want to test this, select your ae cs3 application and choose file>get info. check the box that says ‘open using rosetta’, then see if you can open any of those older projects in cs3.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Neil Carroll
    April 17, 2008 at 3:59 pm
    Unfortunately, no mac at all. Windows XP.
  • Joeri Kassenaar
    May 26, 2008 at 10:42 am
    Same problem here.
    WindowsXP.
    Fresh CS3 production premium install on QT Pro 7.4.5
    (AE 8.0.2.27 “Quicktime installed”)
    Cant open any .mov ( not raw, nothing AE7 opens them just fine).
    I’ve renamed all folders in
    C:\Program Files\Adobe\Adobe After Effects CS3\Support Files\Plug-ins\Format\MediaIO
    to names without ( )..
    So made codecs from (codecs).
    It seems to work now except for large files over a network.
    Same .mov on a local disk works…
