Activity Forums VEGAS Pro Error while rendering my finished video!!
  • Error while rendering my finished video!!
    Posted by Tony Vo on February 21, 2011 at 7:52 am
    Hello!! Just a few weeks ago I’ve been able to edit videos and render everything just fine, the usual 720p, etc. So now that I have to make another video I’ve been getting these errors, at first I had the problem of “Too low on memory” error so I followed other threads and it told me to change the Dynamic Ram Preview Max to 0, and the Maximum number of rendering threads to 1. After that now I get this error while rendering my video, if someone could help me I would deeply appreciate it!
    Extra Information
    File: C:\Documents and Settings\Tony\Local Settings\Application Data\Sony\Vegas Pro\9.0\dx_video_grovel_x86.log
    File: C:\Documents and Settings\Tony\Local Settings\Application Data\Sony\Vegas Pro\9.0\dx_grovel_x86.log
    File: C:\Documents and Settings\Tony\Local Settings\Application Data\Sony\Vegas Pro\9.0\vst_grovel.log
    File: C:\Documents and Settings\Tony\Desktop\TonyJoeFight.veg
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 9.0 (Build 563)
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Program Files\Sony\Vegas Pro 9.0\vegas90.exe
    Fault Address: 0x006D0EBE
    Fault Offset: 0x002D0EBE
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 9.0\vegas90.exe
    Process Version: Version 9.0 (Build 563)
    Process Description: Vegas Pro
    Process Image Date: 2009-04-17 (Fri Apr 17) 15:12:56
    John Rofrano replied 15 years, 6 months ago 3 Members · 6 Replies
  • John Rofrano
    February 21, 2011 at 3:11 pm
    [Tony Vo] “Application Version: Version 9.0 (Build 563)”
    The latest version of Vegas Pro 9 is 9.0e (Build 1147). I would start by updating to the latest build and see if that fixes the problem.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Tony Vo
    February 21, 2011 at 5:56 pm
    Okay thanks I’m gonna try and update now!
  • Tony Vo
    February 21, 2011 at 5:59 pm
    Thanks! I’m trying to figure out how to update, should I just google Vegas Pro 9 is 9.0e (Build 1147) and download it? Or is there a way to just update my sony vegas
  • Matt Crowley
    February 21, 2011 at 6:08 pm
    You can get the latest updates for all versions from the Sony software updates page at https://www.sonycreativesoftware.com/download/updates
  • Tony Vo
    February 21, 2011 at 6:45 pm
    Thank you so much!! After updating that fixed everything!!! THANKSS SOOO MUCHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!
  • John Rofrano
    February 22, 2011 at 1:55 pm
    Glad that worked. The first thing to check is always that you are using the latest update. Vegas Pro will automatically inform you of new updates if you have NetNotify on.
    ~jr
