Activity Forums Adobe After Effects error while accessing external module…
  • error while accessing external module…
    Posted by Francois Moutou on September 16, 2009 at 4:39 pm
    Hello
    I have recurrent issues with AE. It started having various problems but the most common I experience is the one mentioned in the title.
    Don’t know if that’s the correct wording as I translate from my French version of the soft.
    The external modules are integrated ones such as Keylight 1.2 but also Brightness and contrast, shades, color balance… I don’t how it started.
    I worked on CS3, then moved to CS4 + changed the Graphics card (it is supported by Adobe) + format all my discs and re-install everything. Still, the issues come back!
    I run out of options. Does anyone have a clue about what might be happening here?
    Here is my config:
    PC running on XP Pro 32bit SP3
    graphics card: Nvidia GeForce 7900 GT
    processor: Intel Core Duo Quad Q9450 @ 2.66Ghz with 3,25Go RAM
    … which is a decent machine to work on.
    Francois Moutou replied 16 years, 11 months ago 30,254 Members · 1 Reply
  • Francois Moutou
    September 16, 2009 at 4:53 pm
    footage are P2 .MXF mostly… the error occur both while rendering AND exporting
    I’ll turn off Open GL then.
