Activity › Forums › Adobe After Effects Expressions › Error when using toWorldVec when scale is 0
  • Error when using toWorldVec when scale is 0
    Posted by Simon Bjork on October 7, 2022 at 1:39 pm
    I’m using toWorldVec to extract the rotation/scale matrix from a 3d layer, but it seems like this expression breaks when scale is 0. Is there a way around this without changing the actual value of the layer?
    Example:
    thisComp.layer(2).toWorldVec([1,0,0])
    // returns an error if the scale is 0 on any axis.
    Simon Bjork replied 3 years, 11 months ago 2 Members · 4 Replies
  • Dan Ebberts
    October 7, 2022 at 2:25 pm
    Possibly, depending on what you want to happen. You could encase the toWorldVec() in a try/catch clause, but then you have to decide what you want the result to be in that case:
    try{
    }catch(e){
    [1,0,0]
    Or maybe you could have an invisible layer that isn’t scaled parented to the layer that is scaled and get the x vector from the one that isn’t scaled. It depends on what your situation is.
  • Simon Bjork
    October 7, 2022 at 3:16 pm
    Thanks for the reply Dan.
    Yes, that would work. But as the toWorlVec is both rotation and scale, I guess rotation is lost as well in that case?
    I’m exporting objects to other applications and therefore I need to extract the world matrix of objects.
  • Dan Ebberts
    October 7, 2022 at 4:11 pm
    I’m guessing the math behind toWorldVec just doesn’t work if scale is zero. So at that point maybe rotation has no meaning? I’m not sure.
  • Simon Bjork
    October 7, 2022 at 6:13 pm
    Yes, I think so too. It would have been nice if it internally changed 0 to 0.0001 or something. I guess the only way around this is to build the matrices from scratch manually.
    Or just alert the user if the scale is 0.
