Activity › Forums › Adobe Encore DVD › Error when trying to Export to Flash – CS3
  • Error when trying to Export to Flash – CS3
    Posted by Lex Park on July 10, 2007 at 1:39 pm
    I’m attempting to export my very small test project as Flash, but two errors occur:
    1. Adobe Encore has encountered an error. [..\..\src\AMEEncoder.cpp-2359]
    There is only a “Continue” button to click, so I click it and the Build Progress bar finishes and states “Completed”. I then click “OK” and get this second error:
    2. “An input contract violation has occurred!”
    There is only an “OK” button to click, so I click it and that’s it.
    I try to play the swf or index.html that was created and though the Flash build opens to my main menu, complete with correct navigation and highlights states, their respective videos do not playback when selected from the menu. Only a blank black screen appears. If I click Pause or Play respectively, nothing changes, but I can select the “Next” button and it initiates my set end action for that clip and correctly returns me to the main menu. So, some of the settings stick, but video playback does not.
    Some other info about this Encore project:
    From Premiere Pro CS3, I used the “Export to Encore” export option. I selected “Author With Menus”, and changed my Encoding Settings to a custom setting of:
    NTSC, 720×480, 29.97 drop frame [fps], Progressive, Quality 5.0
    192 [kbps], 48kHz, 16 bit, Stereo, MPEG
    CBR, 9.00 [Mbps]
    It successfully encoded without error and opened Encore and such.
    Hope I have provided enough info…
    – The Foonshoe
    Lex Park replied 19 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
