Activity Forums Adobe Encore DVD Error when trying to burn a DVD while using .scc files
  • Error when trying to burn a DVD while using .scc files
    Posted by Bp on December 31, 2008 at 2:12 pm
    Hello Everyone,
    I’m getting the following error when trying to incorporate .scc files into my NTSC standard DVD project in Encore 3.0.
    Could not create “Project Media.acx” Access was denied.
    Has anyone out there had this error before?
    Thanks for any insight-
    Brad
    Kate Pleasant replied 16 years, 7 months ago 3 Members · 5 Replies
  • Joe Bowden
    December 31, 2008 at 6:25 pm
    At what point do you get this error?
  • Bp
    December 31, 2008 at 8:32 pm
    Joe,
    At this error at the point where I hit “build” to make the DVD.
  • Joe Bowden
    December 31, 2008 at 9:01 pm
    So you have already successfully added the scc file to the video asset in your timeline, and then this error comes up when you try to build the project?
    Are you sure the error is due to the scc file? Does the project build without error if you remove the scc file?
  • Bp
    January 1, 2009 at 4:39 pm
    The project burned fine before implementing the .scc files but I will double check first thing in the morning back at work.
  • Kate Pleasant
    February 5, 2010 at 9:46 pm
    I am having the same problem. When I try to burn a DVD with an added scc file, it errors and says something about Line 21 streaming when I try to preview, which I assume is because you can’t preview captions on Encore, but it still errors on the burning process…any help would be great if someone else knows what the issue is!
