Activity Forums VEGAS Pro Error when rendering when setting Constant Bit Rate
  • Error when rendering when setting Constant Bit Rate
    Posted by Ron Whitaker on August 16, 2012 at 6:20 pm
    I wanted to experiment in the Render As dialog.
    I’m using the MainConcept AVC/AAC (*.mp4) container.
    In the Custom Settings dialog, I’m choosing the “Constant bit rate (bps)” option and setting it to 4,000,000 to start.
    When I click the Render button, I receive the following error:
    “An error occured while creating the media file .
    The system is low on memory. You may be able to reduce memory usage by closing other applications.”
    I don’t have anything else open except for a browser.
    I have 8GB of RAM on an Acer Core i7 laptop.
    It’s interesting that when I have the default selected:
    “Variable bit rate
    Maximum (bps): 24,000,000
    Minimum (bps): 12,000,000”
    It renders without any errors.
    Any ideas as to why this is occurring?
    Stephen Mann replied 14 years ago 3 Members · 4 Replies
  • Jeff Schroeder
    August 16, 2012 at 6:49 pm
    Ron,
    Are you rendering an mp4 or an mpeg-2 transport stream. (check the system tab.)
    Jeff
    2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
  • Ron Whitaker
    August 16, 2012 at 9:05 pm
    I’m not sure. I think mp4.
    If I go into the System tab, within the Notes section it reads:
    “Use this setting to create an MP4 (AVC/AAC) file for progressive internet downloads.”
    Next to Format, it reads:
    “Audio: 192 Kbps, 48,000 Hz, 16 Bit, Stereo, AAC
    Video: 23.976 fps, 640×360 Progressive, YUV, 12 Mbps
    Pixel Aspect Ratio: 1.000”
    Does that help?
  • Jeff Schroeder
    August 16, 2012 at 10:02 pm
    Ron,
    I’m sorry I thought you were using the Sony AVC. I prefer the Sony AVC codec, probably because I’m pretty simple minded.
    I don’t have much experience with the MC AVC, but it should not have memory problems. Does the “Enable progressive download” option have any effect on the outcome? I don’t think I’ll be able to help you on this one.
    Jeff
  • Stephen Mann
    August 18, 2012 at 10:03 pm
    Search the forum for “low memory”. The question had been answered dozens of times.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
