Activity Forums Apple Final Cut Pro Legacy error when rendering “The specified file is open…”
  • error when rendering “The specified file is open…”
    Posted by Don Forschmitt on May 19, 2005 at 12:15 am
    Recently, I have been getting the following message when I render. It happens occassionally when I am selecting all and rendering or sometimes when I select an in and out and render between.
    Nothing else is running when I do this.
    “The specified file is open and in use by this or another application”
    I also notice I have to hit the apple-R keys a few times to get it to render. Is there something I am missing here.
    Not critcal, but a bit annoying. Thanks for any insight.
    FCP 4.5 HD
    Dual 2gig G5
    1 gig RAM
    2 internal drives 160GB/250GB
    G-RAID 500 GB
    UVW-1800
    DSR-11
    AJA IO la
    http://www.primelight.net
    Don Forschmitt replied 21 years, 4 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    May 19, 2005 at 12:39 pm
    This sounds like an OS problem… might run Macjanitor and repair permissions, but if this fails, I’d do a reinstall of the OS.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Arnie Schlissel
    May 19, 2005 at 6:27 pm
    [Don Forschmidt] “”The specified file is open and in use by this or another application””
    [Don Forschmidt] “Nothing else is running when I do this.”
    Nothing? Sounds like the classic virus protections message. If you have any antivirus software installed, you must disable it. Better still, uninstall it.
    Arnie
    https://www.arniepix.com
  • Don Forschmitt
    May 19, 2005 at 9:29 pm
    Thanks Amie:
    That was it. I was thinking major problem. Worring about for the past week. And poof!!! you had the answer. Thanks so much.
    don forschmidt
    FCP 4.5 HD
    Dual 2gig G5
    1 gig RAM
    G-RAID 500 GB
    UVW-1800
    DSR-11
    AJA IO la
