Activity › Forums › Avid Media Composer › Error when play timeline
  • Michael Hancock
    March 16, 2007 at 8:38 pm
    If you have a Mojo or Adrenaline (you don’t say what system you’re on)….
    Shut down Avid. Unplug the Mojo/turn off the Adrenaline. Wait a few minutes. Plug the Mojo back in/restart the Adrenaline box. Restart Avid. Try to play it again. If it still doesn’t work, delete the media and recapture it–it’s likely corrupt. If you do have to recapture, hopefully you brought it in with accurate timecode so you can just select the clip, hit Batch Capture, then walk away while it’s brought back online.
    Michael.
