Activity Forums Adobe After Effects Expressions Error when pick-whipping properties across comps: “After Effects warning: layer named ‘…’ is missing or does not exist. It may have been renamed, moved, or deleted, or the name may have been mistyped. A property expression referencing it
  • Error when pick-whipping properties across comps: “After Effects warning: layer named ‘…’ is missing or does not exist. It may have been renamed, moved, or deleted, or the name may have been mistyped. A property expression referencing it
    Posted by Michael Lansdell on June 16, 2016 at 11:26 am
    I’m picking whipping some properties of a few layers across comps, so I can have a pre-comp update to match my main comp so I can use it as an obscuration layer for filters to reference. Not that should be relevant but I want a layer in Element 3D to be able to block a lens flare from Optical Flares.
    When I do it I get this error:
    “After Effects warning: layer named ‘…’ is missing or does not exist. It may have been renamed, moved, or deleted, or the name may have been mistyped. A property expression referencing it was disabled.”
    (see attached for full info)
    In my pre-comp I have a camera, a null and an Element 3D layer. The camera layer let me pick-whip the different variables across the two comps fine, but the null won’t let me do any! Any come across this?
    I’m using AE CC 2014 on OS X 10.10.2. If you need any more info please let me know, thanks!
    comp("Earth").layer("Camera Control").transform.position
    Dan Ebberts replied 10 years, 3 months ago 3 Members · 3 Replies
  • Michael Lansdell
    June 16, 2016 at 11:31 am
    It also won’t pick-whip the Element 3D variables. Probably should have mentioned that!
    I made the pre-comp by duplicating the main comp, if that might have any impact?
  • Kalleheikki Kannisto
    June 16, 2016 at 2:42 pm
    I can’t reproduce the problem. Can you upload a screen shot of your setup (the comp timelines) and what you’re trying to link to what when this occurs?
  • Dan Ebberts
    June 16, 2016 at 4:47 pm
    Is it possible you have more than one comp named “Earth”? If so, the expression may be probably finding the wrong one in the project bin.
    Dan
