Activity Forums Apple Final Cut Pro Legacy Error when importing XML file
  • Error when importing XML file
    Posted by Mikhail Goldfarb on December 14, 2008 at 4:56 am
    The following error message appears when I import the XML file into FCP 5 exported form Logic Pro 8:
    Unable to transfer data value as an audio or video parameter is out of range.( line 36 )
    Any solution?
    Thanx 🙂
    Sean Oneil replied 17 years, 8 months ago 2 Members · 1 Reply
  • Sean Oneil
    December 14, 2008 at 8:53 am
    I have no clue, but it might be worth opening the XML in Textedit and seeing what’s on line 36.
    Sean
