Activity Forums Adobe After Effects Error when importing TGA sequence
  • Error when importing TGA sequence
    Posted by Filip Vandueren on March 18, 2007 at 12:17 pm
    Hi All,
    I just rendered out a tga sequence from after effects, now want to re-import.
    I get the error:
    After Effects error: zero denominator in ratio multiply.
    ( 17 :: 17 )
    similar errors have plagued other cow-members but no solution as of yet ?
    I would suspect the ratio regards pixel aspect ratio, mine is square 1024*576.
    I can import every TGA as a footage, but not the sequence. Quicktime pro also has no problem importing.
    Todd Schmidt replied 19 years, 6 months ago 4 Members · 4 Replies
  • Elorah Dannon
    March 18, 2007 at 6:58 pm
    (Sorry this is off topic)
    Filip! I had a question for you, but my Yahoo mail account was hacked and I lost access to your email address. :< Would you mind emailing me at my new address so I can contact you privately? elorahdannon@gmail.com
  • Steve Roberts
    March 18, 2007 at 7:12 pm
    Filip, can you try running a do-nothing-but-save PS action on the TGA sequence to, er, “launder” the files?
    Alternately, could you try “force numerical order” when importing? It doesn’t make sense, but you never know.
  • Filip Vandueren
    March 18, 2007 at 7:17 pm
    Hi Steve,
    allready tried those, even converted to Tiff with graphicconverter, to no avail.
    perhaps a quicktime problem…
  • Todd Schmidt
    March 18, 2007 at 7:23 pm
    The targa sequence, did you finish the entire sequence from where you rendered that from? I believe that I had a problem before when I rendered an animation from 3DS Max and the entire sequence had not finished. Anyhow, just throwing that out there.
    Todd
