Activity › Forums › Apple Final Cut Pro Legacy › Error when I output HDCAM project to deck using Kona 2
  • Error when I output HDCAM project to deck using Kona 2
    Posted by Steven Escobar on September 9, 2006 at 3:37 pm
    I’m trying to output a feature from FCP5 with Kona 2 card @ 23.98 8 bit to a HDCAM F500 but when I go to Edit to Tape it gives me a Incompatible compression settings error. It also says the following: “You may have attempted to output a clip with compression settings that do not match the current output settings. Try nesting the clip in a sequence the correct settings.”
    I’ve tried that and even looked in the audio/video settings in FCP and tried to change the name but no good. Anyone have this problem? Anyone have a solution? HELP I need to output with TC matching the sequence for a festival and I only have the deck this weekend.
    Steve
    Steven Escobar replied 20 years ago 3 Members · 5 Replies
  • Jerry Hofmann
    September 9, 2006 at 3:39 pm
    What are the sequence settings you’ve used?
    Jerry
  • Jerry Hofmann
    September 9, 2006 at 3:54 pm
    What are the kona’s control panel set to do?
    Jerry
  • Steven Escobar
    September 9, 2006 at 4:20 pm
    Everything is set for 23.98 8 bit Uncompressed
  • Shane Ross
    September 9, 2006 at 5:17 pm
    Did you black the tape properly?
    Did you drag the sequence from the browser into the Edit to Tape window?
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Steven Escobar
    September 10, 2006 at 5:41 am
    Thanks guys…. I knew it was some simple step I was doing wrong. I just needed to drag the sequence to the edit to tape.
