Activity Forums Adobe Premiere Pro Error when creating movie from Premiere – Help!
  • Error when creating movie from Premiere – Help!
    Posted by Sean Tatalovich on April 14, 2009 at 8:42 pm
    I have a project due tomorrow morning. My movie is edited in Premiere CS3. When I try to use the Adobe Encoder and render it out as a QT movie, Using H.264 I get an error saying dropped frame and, memory low. QT error 2048?
    Please what can I do?
    Lucas Windsor replied 17 years, 4 months ago 2 Members · 1 Reply
  • Lucas Windsor
    April 14, 2009 at 8:49 pm
    First and foremost you need to make sure that no other program is running and that you get rid of any unneccary processing running in the background. It sounds as if you don’t have enough memory to render the whole file.
    Try restaring first and if that does not work I would call adobe.
    How much RAM do you have and how big is the project, in terms of minutes?
