Activity › Forums › Boris FX Particle Illusion › Error when creating AVI!!!
Posted by The_man_need_help on October 13, 2006 at 8:31 amHello!
I am having a problem when creating a avi file, it shows up a windows error message, then the progam totaly shuts down.
(click on image for zoom)
Alan Lorence replied 19 years, 10 months ago 4 Members · 6 Replies -
Vaderkrypt
October 13, 2006 at 6:19 pmtry picking a different rendering engine like divx ou 3ivx D4
Elvis Deane
October 15, 2006 at 4:21 amOnce you select AVI as your file type to render to, and hit Ok on the Output Options page, a pop-up should appear asking you to choose a Compressor codec. Do you ever get to the window, or does pI crash before that point?
Can you render to image sequences, or are those causing you problems too?
Elvis Deane!
The Apprentice Magician’s Guide to particleIllusion
The_man_need_help
October 16, 2006 at 2:43 pmwell, thats where i crash, i cant enter the Output Options page 🙁
Please help me… -
Alan Lorence
October 16, 2006 at 3:16 pmWhat stage size are you using? If it’s something weird, or if the stage window is not large enough to show the entire stage area at 100% zoom, then the render size being passed to the codecs may be causing one of them to have a problem. As a test, make the stage size 320×240 and then try it.
If it still crashes, then you might want to try this:
https://www.free-codecs.com/download/Sherlock_The_Codec_Detective.htmI haven’t used “Sherlock – The Codec Detective”, but it sounds useful.
Alan.
wondertouch -
Alan Lorence
October 16, 2006 at 3:19 pmActually, I just tried Sherlock, and it lists all of my codecs, and showed me that one of them was broken (I think because it was a time-limited demo version that expired).
Why doesn’t Windows have something like this built-in?
Alan.
wondertouch
