Activity Forums Adobe Encore DVD error when burning
  • error when burning
    Posted by Joe Feng on February 14, 2006 at 9:43 pm
    When I started a burn, I get the following error:
    operating system error: number=0x00000020 – The process cannot access the file because it is being used by another process.
    I have nothing else open…Please help!
    Sam Yohannan replied 20 years, 6 months ago 5 Members · 7 Replies
  • 7 Replies
  • Aanarav Sareen
    February 14, 2006 at 10:08 pm
    Are you using Encore 2.0 or Encore 1.x? Also, do you have any other Adobe apps running in the background?
  • Joe Feng
    February 14, 2006 at 10:23 pm
    I’m using 2.0.
    I had photoshop running the first time when I got the error. Then I closed everything else and tried again, still got the error.
  • Mark
    February 15, 2006 at 12:23 am
    I get these errors sometimes with other software…I always find it a good idea to do a shutdown before burning a DVD…I also make sure that any antivirus software is closed.
    Mark
    (Have not yet had this issue with Encore using the above method)
  • Joe Feng
    February 15, 2006 at 4:08 pm
    I went in and manually deleted almost all the temp files in the project folders created by Encore for the project. Basically deleted everything I could with Encore still able to open the project. Then it asked me to re-locate all the media files and reimported them. After all this, it was able to burn again.
  • Dominique44
    February 27, 2006 at 6:35 pm
    Hi
    I have the same problem , What have you deleted in the encore project ?
    the sources folder or the cache folder
  • Dominique44
    February 28, 2006 at 10:34 pm
    After many checking, I must erase the folder transcribes to be able writing on the dvd or folder without error.
    It’s a other bug for encore dvd 2.0
    dominique
  • Sam Yohannan
    March 23, 2006 at 11:42 pm
    SO can anyone tell me exactly what files I need to delete in prder to get this error to go away?
