Activity Forums Apple Final Cut Pro Legacy Error: Unknown File
  • Error: Unknown File
    Posted by Les Kaye on July 19, 2005 at 4:48 am
    Dual 2.5 G5
    FCP 5.02
    Kona
    Anyone see this?
    Receive “Error Unknown File” when trying to save, and system does not allow Save or Save as – error popped up each time (twice today and has happened previously to others). Only solution was to exit, relaunch FCP, create a new project with the exact same name as the corrupted/now missing project, then do a restore, which worked perfectly.
    TIA,
    -Les
    Jeff Handy replied 21 years, 1 month ago 3 Members · 2 Replies
  • Steve Drew
    July 19, 2005 at 9:49 am
    Yeah it’s happened on and off. It usually occurs if you’ve had network drives mounted and have un-mounted them while FCP is still open. Try saving the project to another drive, that’s worked for me before.
  • Jeff Handy
    July 19, 2005 at 4:47 pm
    I find that this happens only after leaving my system on overnight. If I do leave it on overnight, I restart the Mac before working on any projects. That works for me. Haven’t tried just logging out and back in. That seems to work for some of our SAN problems.
