Activity Forums Adobe After Effects Error: Unable to find layer “end slices” layer.
  • Error: Unable to find layer “end slices” layer.
    Posted by luke di on September 2, 2025 at 8:49 am
    I encountered the following expression error when using the Sclice It Up plugin to fragment an image composite:
    However, this layer does exist in my composition, and the top-left effect has been added.
    I suspect this might be because the expression for the layer within the composition is linked to the composition, but that still doesn’t make sense.
    As a plugin designer, I shouldn’t run into this kind of problem.
    I’m hoping someone can provide an optimized code solution. I’ll try to decompile and optimize it later.
    luke di replied 1 year ago 2 Members · 2 Replies
  • Dan Ebberts
    September 2, 2025 at 10:49 pm
    Is it possible that there is more than one comp with that name?
  • luke di
    September 3, 2025 at 6:37 am
    Thank you, man. That’s the question, I have to give you a big thumbs up
