Activity Forums Avid Media Composer error trying to bring XDCAM EX clips through MC5 AMA
  • error trying to bring XDCAM EX clips through MC5 AMA
    Posted by Roi Turnoy on August 2, 2010 at 10:09 am
    Hi guys
    I’m trying to bring into my MC5 (MAC & PC) clips that was shot on an XDCAM PMW-EX3 camera through the new AMA tool, and always get this error:
    There were errors linking to AMA files. See the console for details.
    I looked at the console and this what I got when I tried to do the Link to AMA Files option:
    [ Plugin Name = MVP_MSP_QuickTime Vendor Name = Avid Technology, Inc. Version = 1.0 ] does not support /Users/roiturnoy/Desktop/043_0246_01/043_0246_01.MP4
    Do I need XDCAM Plugin to do this?
    What do I need to do that it will work?
    By the way, the data from the SxS was copied to an external drive.
    Thank
    Roi
    Lars Grau replied 16 years, 1 month ago 3 Members · 6 Replies
  • Dan Marlow
    August 2, 2010 at 2:03 pm
    Just a quick though – was the BPAV folder structure copied intact?
  • Roi Turnoy
    August 2, 2010 at 2:05 pm
    Hi
    I’m trying to figure it out
    What should be the correct BPAV folder structure?
  • Dan Marlow
    August 2, 2010 at 3:06 pm
    Should look something like the picture found in this thread –
    https://forums.creativecow.net/thread/142/863026
  • Lars Grau
    August 17, 2010 at 11:37 am
    Same issue here. I am running MC5 on Windows 7 (64bit). MP4 files from EX3 were copied onto an external haddrive. I’ve already checked the BPAV folder structure, which is intact. I do point the “AMA import file(s)” dialog to the .mp4 file, correct? Any solution?
  • Roi Turnoy
    August 17, 2010 at 12:26 pm
    My problem was that the file structure was broken. I guess the man who copied the files to the HDD didn’t really know what he was doing…
    So if you kept the folder structure intact I don’t think of a reason that it wouldn’t work.
    You should try choosing the main root of the folders when using “AMA import Volume”.
    hope it will help you
  • Lars Grau
    August 18, 2010 at 9:57 am
    Got it working. Instead of using “AMA link to file(s)” I have to use “AMA link to volume” instead and point to the BPAV folder. I still find it a little strange that the “link to file” option doesn’t work as expected.
