Activity › Forums › Adobe After Effects › Error: The layer exceeds maximum size
  • Error: The layer exceeds maximum size
    Posted by Kenny Miracle on February 11, 2012 at 9:39 pm
    I’ve been working on a project in After Effects CS5.5 for several weeks and am suddenly getting the error: The layer exceeds maximum size.
    I have not found any info about this error on the AE help manuel or COW forums.
    The project also crashes about every other hour with the Exception Type: EXC_BAD_ACCESS (SIGABRT)
    Comp Settings:
    1280×720
    Square Pixels
    29.97 fps
    Any thoughts?
    Kenny Miracle
    Editing | Motion Graphics
    http://www.kennymiracle.com
    iMac OS 10.6.8 12GB Ram
    2.66 GHz Intel Core i5
    ATI Radeon HD 4850 Graphics Card
    Vasilis Kaminaris replied 10 years, 4 months ago 5 Members · 5 Replies
  • Kenny Miracle
    February 11, 2012 at 10:34 pm
    Well I figured it out 🙂
    Had the CC RepeTile effect expanding a layer to 20,000, which is the max for that effect. When the amount was lessened the error stopped happening.
    Hopefully, this will as least help someone else!
    Kenny Miracle
  • Richard Garabedain
    January 30, 2013 at 8:00 pm
    Yes, you did figure it out, and a big help to me it was.
  • Kris Waterman
    March 1, 2013 at 5:38 pm
    Big help to me as well. Was getting that error AFTER each render, but this morning was getting it prior to each frame being rendered. Big help, thanks!
  • Josh Helfferich
    March 11, 2014 at 7:50 am
    Thank you from 2014!
  • Vasilis Kaminaris
    June 2, 2016 at 6:05 pm
    I had the same problem but i was on 15000 pixels on RepeTile. Though it seems that in CC 2014 the limit is 15K (or somewhere beneath it). I reduced it to 12000 and renders fine.
    Thank you much for the tip.
