Activity Forums Maxon Cinema 4D “Error – Saving Image” message
  • “Error – Saving Image” message
    Posted by Alex Reardon on March 8, 2012 at 4:06 am
    Here’s something new to me, and I hope not new to you guys….
    I’ve been working on a new design from a template file that’s been working very well for a while. Now I can’t render the short animation to the Render Queue. Its only 450 frames and after 25 to 30 seconds, I get an error message
    It asked me to check codec settings and write permissions. Write perms are fine. Where do I find codec settings?
    Any other tidbits would be helpful.
    Thank you all as ever.
    -A-
    Rajesh Barnabas replied 11 years, 6 months ago 3 Members · 2 Replies
  • Randy Johnson
    March 15, 2012 at 3:23 pm
    if the file is open anywhere else you cannot save.
    /Randy
  • Rajesh Barnabas
    February 20, 2015 at 2:11 am
    Here are some causes I have run into:
    1) not enough disk space to render out your project.
    2) file name too long and complicated
    3) rendering out movies are sometimes a pain from C4D, it is best practice to export as an image sequence and then build it back together in After Effets, Motion, Premiere, Final Cut, etc, or QuickTime Pro. There are also free compilers, just google them. This way if your project stops rendering you still have something..
    4) also if it is a long animation, make sure the computer’s sleep time or energy saver is set to Never…
