Activity Forums Adobe After Effects ERROR: Render Graph Stack Overflow — Composition Too Complex (78 — 6)
  • ERROR: Render Graph Stack Overflow — Composition Too Complex (78 — 6)
    Posted by Rory Boen on August 8, 2013 at 4:08 am
    I am working on a pattern composition that includes a sub composition consisting of about 10 vector layers duplicated hundreds of times in a main composition and am running into this problem on AFX CS6:
    Does anyone know if there is a way to bypass such an error by purchasing more RAM, etc? So far masking things before they get imported into AFX has been a difficult method of continuing the project; but it’s not a true solution to the “sound barrier” I appear to of hit for the first time.
    Roland R. kahlenberg replied 13 years ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    August 8, 2013 at 4:47 am
    There’s some info here – https://myleniumerrors.com/2008/12/13/78-6/
    I would look at pre-rendering the lower level pre-comp and look at ways to reduce RAM. This isn’t part of the info in the link above but IT could be memory related.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE
