Activity Forums VEGAS Pro error; render exceeds max file size
  • error; render exceeds max file size
    Posted by Kevin Mccarthy on April 7, 2015 at 5:00 am
    I am trying to render a 3hr 7 min audio file to a wav file to process in my external audio editor. I get a message that render exceeds max file size.
    I have never seen this one before and I can’t find anywhere to adjust limitations
    Any ideas?
    Russ Froze replied 11 years, 5 months ago 4 Members · 8 Replies
  • 8 Replies
  • Kevin Mccarthy
    April 7, 2015 at 5:02 am
    update the error says it exceeds the max limit for file type. I am trying to render to a 48k WAV file
  • Russ Froze
    April 7, 2015 at 6:23 am
    I am curious to know, from where did the file originate, how was it created?
    Russ Froze
  • Kevin Mccarthy
    April 7, 2015 at 1:44 pm
    It is a file from an imported DVD and I usually have no problem qith this type of render from this source
  • Nigel O’neill
    April 8, 2015 at 12:26 pm
    [Kevin McCarthy] “render exceeds max file size”
    Just out of curiosity, are your hard drives formatted to fat, fat32 or ntfs?
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 12 (x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Kevin Mccarthy
    April 8, 2015 at 1:37 pm
    Yes drives are fine and nothing has changed except for the fact that I had just installed the latest update
    Would that have re-set the time line length and if so how do I extend the time line length? I can’t find that setting
    I don’t think this is the problem though as both audio and video are already on the time line and work well
  • Kevin Mccarthy
    April 8, 2015 at 6:07 pm
    Still no solution. I tried to use the “open in external audio program” and it too says render exceed maximum file size for this format
  • Aaron Star
    April 8, 2015 at 6:57 pm
    Try outputting to Wav64, or segmenting the output, or use a compressor like AC3, MP4/MP3. File size limitation was one of the main reasons for WAV64.
  • Russ Froze
    April 10, 2015 at 5:47 am
    [Kevin McCarthy] “Still no solution. I tried to use the “open in external audio program” and it too says render exceed maximum file size for this format”
    Well the only thing I can suggest is to do an analog transfer. Record it to the workstation or an external recorder.
    Russ froze
