Activity Forums Adobe After Effects Error reading/rendering Apple Pro Res HQ files
  • Error reading/rendering Apple Pro Res HQ files
    Posted by Sharad Patel on April 21, 2010 at 4:19 pm
    I’m running into nonstop errors occuring during rendering and even scrubbing through movie files imported into an AE project. I’m on a mac, on AE CS4, on the snow leopard OS.
    The files were rendered at 29.98 fps (apple pro Res HQ codec) out of a previous AE project, but I’m interpreting them at 23.976 fps after importing into a new AE project. I have a feeling that me trying to play them at a slower frame rate is what is causing the problem.
    Does anyone else have this problem? Or are you able to recreate the situation and error?
    The error: “Error (4) reading frame from file “/Volumes/FINAL FRONTIER/final frames and edit/scene 02 24p.mov”. (86 :: 2)”
    I prefer Rob Bottin to Rick Baker
    Sharad Patel replied 16 years, 5 months ago 33,396 Members · 4 Replies
  • Sharad Patel
    April 21, 2010 at 5:40 pm
    I did mean 29.97, and I’m interpreting the footage at 23.976.
    I think I have discovered a problem with apple pro res HQ:
    If you reinterpret 29.97 apple prores HQ footage as 23.976 (it should just play slower) but in after effects or even in final cut pro (where you can change the frame rate interpretation using cinema tools) an apple pro res file will sometimes just freak out and not play or display.
    It must have something to do with the intermediate non-existent frames. The compression must specifically only be able to be decoded at the same framerate it was encoded in.
  • Sharad Patel
    April 21, 2010 at 5:48 pm
    I am on the same machine with final cut 7.0.2
    after effects 9.0.2
  • Sharad Patel
    April 21, 2010 at 6:22 pm
    Yes, I think my only choice is to not go with the apple pro res HQ. I was doing this as an archival/master format that I could handle on my home studio setup.
    I’m plan on some extensive color manipulation later on to the footage and felt like the deeper (but still space economical) the file depth the better.
    What do you recommend? I can easily take my clips into compressor and re-output them into a bigger more stable framed format.
    You recommend pro res 422?
    I could also go with a good old PNG uncompressed frame sequence for each clip.
    thank you so much for the response! Where should I post about this problem with the codec? To warn others?
  • Sharad Patel
    April 21, 2010 at 6:46 pm
    I’m doing work like this:
    https://www.vimeo.com/10036011
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
