Activity › Forums › Adobe After Effects › Error parsing properties list
Posted by Paulo Mateus on January 25, 2007 at 4:33 pmHello
The application crashed and then I can’t open it anymore. Every time I try to open it, the following error message appears: Error parsing properties list.
I’m running After Effects 7 Pro, on a Power Mac Dual G5, my OS it’s the Tiger (10.4.8).
There’s anyone knows what to do? Maybe I have to reinstall it.
PauloShravan Behara replied 16 years, 7 months ago 7 Members · 7 Replies -
Iancorey
January 25, 2007 at 5:00 pmSearched the forums:
https://forums.creativecow.net/readpost/2/878476?univpostid=878456&pview=t -
Paulo Mateus
January 25, 2007 at 6:19 pmI deleted the “Adobe After Effects 7.0 Prefs” as explained in that post, but it stills doesn
Tom Womack
February 12, 2009 at 3:55 pmI had same error – After Effects CS4 – locked up –
I found several posts for this error message‘error parsing properties list’
The issue for me was the difference in Adobe data location in Vista and XP. The ‘cure’ appears to be the same for both and that is removal/recreation of the AfterFX#.ini where # is the release level of After Effects, in my case, AfterFX9.ini, yours AfterFX7.ini
on XP the Adobe data should be in Document and Settings/Local Settings/Appliction Data/Adobe
AppData moved on Vista
on Vista ( not yet documented at Adobe site), this file and data can be found at
users/USERNAME/AppData/Roaming/Adobe/AfterEffects/9.0 where 9.0 is release level and USERNAME is username of pc user account.
I was told to delete entire After Effects directory here, I also see forum posts where deleting the .ini file is all that is necessary.
I deleted folder, accessed AE CS4 immediately.
Hope this helps,
dogcreek
Juan Navarro
September 2, 2009 at 4:00 pmnever is to late…
Solution:
Rename the .xml files from the following folder and its subfolders from .xml to .bak:Windows XP — C:\Documents and Settings\[user name]\Application Data\Adobe\After Effects\9.0
WindowsVista — C:\Users\[user name]\AppData\Adobe\After Effects\9.0
Mac OS — [user name]/Library/Preferences/Adobe/After Effects/9.0
Cheers!
Juan Navarro
Editor Manager
Video Department
Teletón Fundation
Chile Southamerica -
Sandy Scott
November 23, 2009 at 9:02 pmHello,
I just got the same error reading on my After Effects program. Here’s what I did to fix it and it workes great again and it’s very simple. Try this.
go to your C drive
click on your user name in the left menu
click on AppData
click on Roaming
click on Adobe
click on After Effects
click on 9.0
then scroll down and click on the file: AIFEffectCache.xml and rename that file AIFEffectCache.bakThen reopen your After Effects program. It should run perfectly again.
Shravan Behara
January 31, 2010 at 9:15 pmThanks very much. changing to .bak made my day. i m a much happy person nw. it cleared all the glitches i had from so many days.
