Activity Forums DaVinci Resolve Error opening project Davinci Resolve MAC OS
  • Error opening project Davinci Resolve MAC OS
    Posted by Anfet Dry on July 11, 2021 at 2:30 am
    Hi!
    Maybe somebody faced it?…
    Issue:
    Davinci gets error with opening project after adding short circuit link in fusion between custom tool node slider and transform node value center.
    My attemps to fix:
    1 restart mac os
    2 open projects in different order
    3 Open in Read Only Mode
    4 Export Project… Import Project…
    Anfet Dry replied 5 years, 1 month ago 1 Member · 1 Reply
  • Anfet Dry
    July 11, 2021 at 9:12 pm
    So, issue solved, but it is not short foggy way to get few second more for delete remove corrupted sequence and resave project (I tried and did it only one time successfully):
    Export Project… copy Import Project…
    Restart mac os in safety mode (with pressed shift) – it is impossible to open Davinci & because you can’t use GPU in safety mode
    Add & change for random location in Media Storage Locations preference
    Decrease Memory Configuration to minimum
    Change GPU to OPEN CL
    Restart mac os in normal mode
    After these steps I can open new imported project ( maybe for 7 seconds before DaVinci error), clear bad seconds and resave it. Now it works.)…!!!
    I cant’t repeat open corrupted project(..
    So, maybe the steps forced rebuild Davinci’s project condition(I don’t know 8(0) ) and give me the necessary time.
