Activity › Forums › Adobe After Effects › Error on text presets?
Posted by Hamid Rohi-bilverdy on January 13, 2011 at 5:08 pmHi
I wrote some text and from adobe bridge I tried to add a text preset.
I get this error
Why is this showing??
Kevin Camp replied 15 years, 8 months ago 2 Members · 5 Replies -
Kevin Camp
January 13, 2011 at 5:41 pmhave you tried applying the preset within after effects? there may be something in the after effects preset that doesn’t work in bridge.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Hamid Rohi-bilverdy
January 13, 2011 at 5:57 pmNo I have not.
It worked within AE.
How come?? I mean it used to work a coupl of months ago…
Kevin Camp
January 13, 2011 at 7:00 pmhere’s a thread with the same issue:
https://forums.adobe.com/thread/397228
if you are opening bridge from ae (as the 1st solution suggests) then resetting the bridge pref by either removing it from the prefs folder, or holding the option key while starting bridge sounds like it may help… i’m not sure if the poster was referring to a mac or pc ‘option key’, so that may require some trial and error.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Hamid Rohi-bilverdy
January 14, 2011 at 4:15 pmHi Kevin.
Im on a pc, I dont know which key coresponds to the mac option key, I tried the “Alt Gr” key, but no luck…
Kevin Camp
January 14, 2011 at 4:35 pmi just tried it on my mac… choosing animation>browse presets from ae while holding the option key brought up the options reset the prefs.
i believe the option key on a mac is the alt key on a pc, but i may be wrong on that….
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
