Activity Forums Apple Final Cut Pro Legacy Error on DV Start/Stop Detect (HELP!)
  • Error on DV Start/Stop Detect (HELP!)
    Posted by Alieninnovation on July 15, 2006 at 9:03 am
    Hey team,
    I received two DV tapes, which where filmed with a Panasonic Camcorder.
    When I use the DV Start/Stop Detect function I get the Error message:
    “This movie does not contain any time/date information. The camera’s clock may not have been set.”
    Well the Material was then captured through a Canon Camcorder (XL1 I believe) could this cause the error or issues?
    Any help or work around’s?
    Debe replied 20 years, 1 month ago 2 Members · 1 Reply
  • Debe
    July 15, 2006 at 1:36 pm
    Well, if you didn’t shoot it, you don’t know that the camera’s clock WASN’T set. It’s possible FCP is teeling you the truth. It can’t do it becuase there is no data or not the right data available for the function to do what it does.
    It might be time to log instead.
    debe
