Activity Forums Adobe After Effects Error on CS6 launch – unknown exception
  • Error on CS6 launch – unknown exception
    Posted by Sam Freeman on May 29, 2012 at 9:35 am
    Hi guys,
    I’ve just installed CS6 on my iMac and I’m getting an error message on startup. ‘Unknown exception’
    Once you acknowledge this dialog you can continue and the program loads fine, but I worry that something’s not quite right under the hood. It’s seems to always be when it tries to load the ‘Resources’.
    So far I’ve trashed the preferences and done a reinstall. Any other ideas?
    Thanks – hope you guys can help
    Sam
    iMac 3.4ghz i7
    16GB Ram
    OSX 10.6.8
    AMD Radeon HD 6970M
    CS6 11.0.0.378
    I also have CS5 and 5.5 installed on this machine
    Carlos Cobas replied 13 years, 1 month ago 4 Members · 11 Replies
  • 11 Replies
  • Roland R. kahlenberg
    May 29, 2012 at 10:13 am
    Try updating to 11.0.1 here ->https://blogs.adobe.com/premiereprotraining/2011/06/updates-for-adobe-premiere-pro-after-effects-and-adobe-media-encoder-cs5-cs5-5.html
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Sam Freeman
    May 29, 2012 at 10:50 am
    Thanks for the response Roland – unfortunately no joy though.
    May 29, 2012 at 11:09 am
    Hi Sam, a COW Search found these – https://forums.creativecow.net/readpost/2/931494
    HTH
    RoRK
  • Sam Freeman
    May 29, 2012 at 11:15 am
    Yeh, I found that link thread before – always search the forums before posting ;0) – but neither trashing the prefs folder for After Effects 11, nor CMD+OPTION+SHIFT did me any good.
    I know it’s odd but maybe I should trash the preferences for CS5 and 5.5 – it must have sourced them from somewhere on initial startup…
    I’ll try that.
  • Sam Freeman
    May 29, 2012 at 11:29 am
    Nope – no joy there either. Any other thoughts?
    May 29, 2012 at 12:21 pm
    Nyet! Give the Adobe Forums a try – https://forums.adobe.com/community/aftereffects_general_discussion.
    They’re actually the best place for app issues such as this.
    Good Luck!
    RoRK
  • Sam Freeman
    May 29, 2012 at 6:33 pm
    Thanks for your help Roland!
    May 29, 2012 at 8:35 pm
    Sorry it hasn’t worked out. Perhaps ‘google’ the error message. BTW, do you have any 3rd party plugins installed that may be the cause?
    Good Luck!
    RoRK
  • Sam Freeman
    May 29, 2012 at 9:22 pm
    I don’t have any currently in the the CS6 folder as it’s a totally new install, but I do for CS5. Maybe I’ll ditch a few things from my old plugin folders and do a bit of old fashioned trail and error – might be worth a try.
  • Tom Daigon
    May 29, 2012 at 9:47 pm
    Sam, I am having the exact same problem. It stops when it sees my Core Melt plugins on boot up. When I remove them, it then happens on the Resources folder just like your screen grab shows . But the plugins work just fine in AE. So I have been ignoring it. I am curious about any solution you may find.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.7.3
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
