Activity › Forums › Adobe After Effects › ERROR: not enough memory to create image buffer
Posted by Milton Hockman on February 17, 2006 at 8:22 pmWhat does this error mean? I am trying to render out a Avid Meridien Compressed comp.
Dflamholc replied 20 years, 6 months ago 3 Members · 3 Replies -
Bobby Mosaedi
February 17, 2006 at 9:09 pmive had this error when using the basic 3d function. if you are using basic 3d, try redoing what you did and convert your layer to a 3d layer and manipulate using transform. i could be way off on what youre problem is though…
Dflamholc
February 18, 2006 at 3:18 pmI just answered on a post below regarding this too, i don’t know exactly what it might be in your case, but when i got that same error, time and time again, for no particular reason I thougth, it was because i had a huge solid layer on something like 15650×15650 pixels… which was because i had created a 1080 comp size solid and then made it several hundred procent bigger to be able to move around on it with a camera. i don’t think the 3d layer function of the layer had much to do with the image buffer error i got, but certainly when I reduced the size of the layer ae had no problem rendering it. i ended up using it on like 8000×8000 which was big enough.
for a long time i thought that it was the 6 lights i had in the comp that created rendering problems, but that all worked fine when i had sorted the large layer out.
hope you work it out somehow, i have no idea if above would appy to you in any way …/ d
