Activity › Forums › Panasonic Cameras › Error: No Data
Error: No Data
Posted by Chris Eldridge on October 29, 2008 at 5:44 amWhen I attempt to import files from my p2 card, either through a FW400 linked to the HVX or through a card reader, only some of the files will import. here’s a screengrab of what it looks like:
When I mouse over the exclamation point I get the message “Error: No Data”. Anyone know what the problem could be?Jason Scholder replied 15 years, 3 months ago 5 Members · 10 Replies -
Noah Kadner
October 29, 2008 at 2:21 pmWhat happens when you copy the entire folder contents to a hard drive first?
Noah
My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
Now featuring the Sony EX1 Guidebook, DVD Studio Pro and Sound for Film and TV.
https://www.callboxlive.com -
Chris Eldridge
October 29, 2008 at 2:26 pmThe same thing happens.
I’m running FCP 5.1.4- could this be the problem?
The clips were shot at 720/30PN -
Chris Eldridge
October 29, 2008 at 2:28 pmMy workaround is to use the mxf files in FCP, but I don’t know if anything is being sacrificed if I do that.
Noah Kadner
October 29, 2008 at 7:17 pmI’d move up to 6.0.4
Noah
Chris Eldridge
November 2, 2008 at 5:19 pmThanks, I just did, and I had the issue again. I think I’ve solved it though:
in the log and transfer window, in the ‘advanced’ drop down menu (looks like a little gear), go to the preferences option, and I had “Remove Advanced Pulldown and Duplicate Frames” checked from a previous project. When I deselected that option everything worked fine. -
Nicolas Romolini
November 30, 2009 at 4:54 pmhmm, i’m having this issue as well. i’ve tried to uncheck remove advanced pulldown and it still isn’t working. does anyone have any further advice? i’ve also trashed my prefs and repaired disk permissions.
any help would be greatly appreciated.
thanks!!
Chris Eldridge
November 30, 2009 at 5:31 pmDid you set in and out points for your clips? If not, try doing that (even if it’s the first and last frames of the clip). That has helped me when I’ve had other errors.
Nicolas Romolini
November 30, 2009 at 6:51 pmi just tried setting in and out points.. and still no luck. any other suggestions? thanks again.
Jeff Fedigan
March 21, 2010 at 11:17 pmI recently posted in the Panasonic P2 Forum and I’m having this issue as well. I’ve read the remedies mentioned and I’m at the same position that Nicolas Romolini is in.
Jason Scholder
June 8, 2011 at 2:56 pmOMG i have been pulling my hair out! what little there is left… i read this from shane, who is very helpful, but i somehow couldn’t find it. thank you for pointing me precisely to the preferences gear wheel. It’s amazing, when you’re frustrated, how easy it is to miss the obvious.
thanks to everyone who contributes answers. you guys rock!
