Activity Forums Adobe After Effects Expressions Error – no active camera?
  • Error – no active camera?
    Posted by Paul Gale on June 12, 2012 at 12:45 pm
    I’m using AE CS6 (v11.0.1.12) and have a strange error that I see has occured before in one or two posts.
    I’ve applied the auto orient on Y axis only expression from Dan’s site (thanks yet again Dan!) to the Y rotation of an illustrator layer. The comp is a pre-comp but has an active camera in both the main comp and pre-comp.
    I get the following error and the expression is disabled:
    No active camera at time xxxxx
    At first it was always at time -00:00:00:01 but then I purged all memory several times and then re-entered the expression. I briefly got it to work and the layer oriented in the Y axis but without touching anything, several seconds later I got the same error but at 00:00:20:00.
    Very weird – got to be a bug maybe unless I’m missing something?
    Any ideas?
    Paul.
    delta = toWorld(anchorPoint) - thisComp.activeCamera.toWorld([0,0,0]);
    radiansToDegrees(Math.atan2(delta[0],delta[2]))
    Jordan House replied 9 years ago 3 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    June 12, 2012 at 3:03 pm
    I’m not seeing that error, but you should be able to work around it by changing activeCamera to layer(“Camera 1”)
    Dan
  • Paul Gale
    June 22, 2012 at 9:25 am
    Many thanks Dan,
    That solved it for that time – I’m still seeing the odd occurrence which is fixed by simply re-pasting in the expression (with activecamera) – something whacky going on somewhere!
  • Dan Ebberts
    June 22, 2012 at 4:02 pm
    The other thing you can try is wrapping the expression in a try/catch construct, like this:
    try{
    }catch(err){
    value
    Dan
  • Paul Gale
    June 22, 2012 at 4:49 pm
    Does that only then evaluate the expression when there’s no error – therefore not disabling the experession if something odd is going on?
  • Dan Ebberts
    June 22, 2012 at 4:57 pm
    That’s correct.
    Dan
  • Paul Gale
    June 22, 2012 at 4:59 pm
    Great thanks Dan – will try that next time.
  • Jordan House
    September 13, 2017 at 2:12 pm
