Activity › Forums › Adobe After Effects › error message
error message
Posted by Dotan Baytman on July 9, 2005 at 8:20 pmhey
what does this error means?
“after effects error: RAM preview needs 2 or more frames to playback”
thanxAharon Rabinowitz replied 19 years, 7 months ago 3 Members · 3 Replies -
Aharon Rabinowitz
July 10, 2005 at 2:22 pmWhat it normally means is that your work are is less than 2 frames. However, I often get this message when My computer has run out of memory, and can’t seem to dump the held RAM.
Save your work.
First try restarting AE. If that doesn’t work, try restarting you computer.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com -
Creativedre
February 23, 2007 at 5:31 amI’m getting the same error “After effects error: ram preview needs 2 or more frames to playback”
Happens when I’m using the “Zaxwerks 3D flag”. After about 4/5 previews the msg pops up.
I save my work, restart, and open the program up again. After about 4/5 previews the msg comes up again.
Why is it doing this..?
Anyone know how to fix this prob.. TIA -
Aharon Rabinowitz
February 23, 2007 at 1:37 pmusually that requires a restart of AE or your computer, but you can try:
Edit > Purge > Image cache
And then if that doesn’t work, try:
Edit > Purge > All
You’ll lose your undo’s though.
Aharon Rabinowitz
http://www.allbetsareoff.com—————————————-
Click the link below to subscribe to the Creative Cow After Effects Podcast, and get free AE video tutorials:https://phobos.apple.com/WebObjects/MZStore.woa/wa/viewPodcast?id=111087911
