Activity Forums Adobe Photoshop Error message with Displacement Map
  • Error message with Displacement Map
    Posted by Jim Ives on October 15, 2009 at 5:00 am
    Hi All,
    When I apply a displacement map I get the following error message: “This layered Photoshop file was not saved with a composite image” I made sure Maximize Compatibility is turned on always and did a save as and overwrote the file and tried again. Same watermark error message. I also did a save as and gave the file a new name. Same thing! I’m stumped on this one and can’t find enough info on the web to fix it. I’m using CS4 and Windows.
    Thanks to anyone who can provide a solution!
    Jim
    Jim Ives replied 16 years, 11 months ago 2 Members · 2 Replies
  • Art Doerge
    October 15, 2009 at 4:20 pm
    Hi Jim,
    To the best of my knowledge, the Displacement Map must be flattened. The image you’re applying the displacement map to does not have to be flattened but I’m pretty sure the map itself must be. If your map is not flattened, do that and try again.
  • Jim Ives
    October 15, 2009 at 7:46 pm
    WOW! I didn’t know that TU much for answering. It worked!
    Jim
