Error message when rendering in AE-“file not found”
This has just recently started and has been happening to every AEP file that I use. I select the composition I want to render, send it to render comp and hit render only to recieve the error message “after effects errors:creating move–file not found(-43)” Everytime!! Even on a file that has previously rendered. Ive checked and rechecked all of the files in the comp, everythings there but nothing will render.
Im using AEP 7.0 on Windows XPHELP!!
