Activity Forums Avid Media Composer Error Message when importing XDCAM footage into Avid Media Composer 5
  • Error Message when importing XDCAM footage into Avid Media Composer 5
    Posted by Robert Sankey on October 5, 2011 at 3:08 pm
    I’m getting an error message when importing an XDCAM clip into Avid.
    It reads:
    Exception MXFDomain WriteIndexTable – Failed to write index table to file
    Any thoughts as to how I can correct this and import properly.
    Thanks in advance,
    RS
    Daniel Huber replied 14 years, 10 months ago 2 Members · 1 Reply
  • Daniel Huber
    October 14, 2011 at 4:29 am
    Hi Robert,
    Are you mounting a XDCAM disk or sxs card through AMA?
    I think you might want to trash your data base files that live inside your Avid Mediafiles folder…Avid Mediafiles/MXF/1 You want to trash the .mdb and .pmr files
    You can also just use the media tool. It is under your tools tab.
    Select the drive letter of the mounted disk or card and all projects within the media tool. That should load the XDcam clips into a bin, you can then move those clips to another bin inside the project.
    Or you can try linking through AMA, then transcoding the material.
