Activity Forums Apple Final Cut Pro Legacy error message when importing image sequence
  • error message when importing image sequence
    Posted by Peter Frick on July 19, 2006 at 11:26 am
    Hi
    When I import a numbered image sequence into FCP, following all the instructions in the manual, I get an error message saying ‘insufficient content for edit’.
    Is this a bug or what?
    Peter
    Peter Frick replied 20 years, 1 month ago 2 Members · 2 Replies
  • John Pale
    July 19, 2006 at 5:24 pm
    fcp does not import image sequences. import into quicktime pro and export as a quicktime movie in the codec you are editing in.
    then import that into fcp.
  • Peter Frick
    July 19, 2006 at 5:54 pm
    Thanks, I just did that. In the manual I got the impression that it should work but in another place I saw your solution described. check out the pages 317-318 in the first manual.
    See you
    Peter
