Activity Forums Zaxwerks Error Message When I Install Zaxwerks For AE CS4
  • Error Message When I Install Zaxwerks For AE CS4
    Posted by Steve Framework on December 12, 2008 at 3:00 am
    I’m trying to upgrade my After Effects to CS4 (from Professional 7.0).
    After I install the AE CS4 I’m trying to install Zaxwerks 3D Invigorator (because a project I’m working on is involved with it). The project when I call it up says I need to “install 3D Invigorator.”
    Then once I do so I’m getting an error message in AE that says: “CAN’T IMPORT FILE ‘3D INVIGORATOR AE PRO 4.0.9’: UNSUPPORTED FILETYPE OR EXTENSION.”
    Any thoughts what I might be doing wrong? I’m following the install directions as indicated.
    Thanks…
    Max Toperzer replied 17 years, 5 months ago 2 Members · 2 Replies
  • Steve Framework
    December 12, 2008 at 4:43 am
    NEVER MIND. I GOT IT.
  • Max Toperzer
    March 13, 2009 at 9:46 pm
    How did you solve your problem?
