Activity › Forums › Adobe After Effects › Error message when i import soundfile
Posted by Waseem Dabbas on April 19, 2011 at 11:47 pmHi, I’m new to AE.
when i tried to import file like Mp3, or wav, it shows me an error message like this
https://www.domisign.com/images/waseem/aep1.JPGI’m using After effect CS3
i hope you find a solution for me
Thank youWaseem Dabbas replied 15 years, 5 months ago 3 Members · 4 Replies -
Brian Charles
April 20, 2011 at 12:00 amI’m not sure why you’re receiving that error but mp3 files should be avoided in After Effects. Convert the file to an aif or wav.
MP3 is a compressed format and will only compress further in AE resulting in audio artifacts.
Waseem Dabbas
April 20, 2011 at 10:55 amThanks for answering, but as i mentioned the problem happen in any Audio format, I try a lot of .wav files, but the problem still the same.
I think there is a technical problem, because the first time i ran AE, a message appear telling me about a problem in Audio recording, but i thought i don’t need any recording service at the moment, so that why i check on “Don’t show me this message again”.
now i have problem with any audio file, also some kind of movies, plus when i try to see my ram render of my video file, there is no sound go out!
I’m sure there is solution for this problem, but i still don’t find who solve it for me. -
Michael Szalapski
April 20, 2011 at 4:06 pmCheck your preferences for audio hardware. Make sure everything is correct.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Waseem Dabbas
April 20, 2011 at 10:14 pmDear friends,
Thank you very much for trying to help, I think it was my fault, i tryed another .wav files, and they are working properly, but in the same times some others doesn’t… I don’t know why.btw, from my first post i said i use After Effect CS3.
Thank you Dave, thank you all.
