Activity Forums VEGAS Pro Error Message – trying to make Blu Ray – Failed to connect to IPC port
  • Error Message – trying to make Blu Ray – Failed to connect to IPC port
    Posted by Ken Kruger on June 24, 2014 at 6:55 pm
    Getting an error message every time I try to make a Blu-ray disc. The video renders, the audio renders, and as soon as it starts to build the image, this comes up: “Failed to connect to an IPC port: Could not find the file specified.”
    I’m on Sony Movie Studio HD Platinum 12.0. Windows 7 (x64) Intel i7 hex core processor, NVIDIA GeForce GTX 650 Ti GPU, 16 GB RAM.
    Rendering timeline to 1920×1080 – 60i, 10mbps video stream.
    I’ve tried changing these parameters every way I can think of, still same error when it tries to compile disc image.
    Any ideas anyone?
    Ken Kruger replied 12 years, 2 months ago 2 Members · 6 Replies
  • Ken Kruger
    June 24, 2014 at 6:56 pm
    Also have tried the render both with and without GPU acceleration. The plot thickens.
  • Ken Kruger
    June 24, 2014 at 7:32 pm
    And the mystery continues…I tried to change a parameter in the render settings, and got a error message: “Status: Found two different objects associated with the same URI.” I have no idea what this means. But it happened at the exact same moment as before…after the video and audio render, just when it begins to compile the disc image.
  • Dave Osbun
    June 25, 2014 at 5:18 pm
    Is the final output location the same drive as where the video & audio files reside? If the answer is “no, it is a different drive letter”, then change the final output path to the same drive where those files are located.
    Not saying this is a fix, but I’m curious what happens.
    Dave
  • Ken Kruger
    June 26, 2014 at 8:15 pm
    Hi Dave, thanks for checking into this. Did what you said, and the exact same thing happens. I have our media on a separate internal drive from the OS. Changed the output folder to the same folder as the source media. Same IPC port error. Then I did a straight up render of the project into an HDV format, stored that file on my primary C: drive, on the desktop, then created a new project, and dropped that render into the timeline, and tried to make a BluRay from that. Exact same error message. I’m stumped, and getting kind of frustrated. Any ideas?
  • Dave Osbun
    June 27, 2014 at 2:04 pm
  • Ken Kruger
    June 27, 2014 at 7:26 pm
    I did look at that post. That was the first thing I checked. I’ve been trying various render settings, but made sure to try every combination available for 1920×1080, which is what the original source video is (AVCHD 1920×1080, 30 fps interlaced). Did I mention that I’m on version 12.0 of Sony HD Platinum Movie Studio, and not Vegas Pro?
