Activity › Forums › VEGAS Pro › error message on blue ray burn
  • error message on blue ray burn
    Posted by Wayne Shields on February 16, 2010 at 11:44 am
    Hi I get an error message-no wrapper on the device or something similar when I am at the prepare stage of a blue ray disc?
    Does this mean anything to anyone or has anyone come across this before?
    Thanks in advance
    Wayne
    Wayne Shields replied 16 years, 7 months ago 2 Members · 4 Replies
  • John Rofrano
    February 16, 2010 at 12:05 pm
    No, but if you can get past the part where it makes the .ISO file, just burn it with ImgBurn or any other free burner.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Wayne Shields
    February 16, 2010 at 6:38 pm
    thanks John but cant even get that far.Thought it might be a size thing but cant for
    the life of me figure it out
    Any other suggestions?Its just a simple blueray. A menu with two buttons(one each side)One is a button leading to a video and on the other side of the menu is a heap of stilsl in a montage with ultimate s,
  • John Rofrano
    February 16, 2010 at 7:01 pm
    Oops.. you did say it was during the prepare stage. Yikes! I’ve never heard of such an error (sorry).
    ~jr
  • Wayne Shields
    February 20, 2010 at 9:46 am
    Finally cracked this with a perfect burn.For those with similar problems there was not enough space in any of the temp files.What you have to do and are better off doing is creating a new temp file on your largest drive and saving it there.Had no clue that there would be insufficient space on the drive in the temp files.Thanks as always Jon Refano-if this helps someone all well and good.
    By the way 1080 on a 50 inch plazma with blue ray is absolutely superb and definitely worth all the hqssle-thanks again guys
    Wayne
