Activity Forums Adobe After Effects Error Message: (Interpolation Method not allowed for this stream)?
  • Error Message: (Interpolation Method not allowed for this stream)?
    Posted by Shannon Wilkerson on September 11, 2008 at 11:47 pm
    Recently I have been trying to animate a 2D texture layer with the wiggler. But when I select the Key frames and then hit apply I get an error message that says “After Effects Error: interpolation method not allowed for this stream (2) (29::13). I tried to fix this problem within the animation options but I have had no luck. If anyone could help me out with this problem it would be greatly appreciated.
    Shannon Wilkerson
    Denver, CO
    Roland R. kahlenberg replied 18 years ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    September 12, 2008 at 1:40 pm
    Sounds like you may have an Expression for those keyframes. Either delete the Expression or better yet disable it to ensure that you don’t need it.
    HTH
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
