Activity Forums VEGAS Pro Error message in rendering
  • Error message in rendering
    Posted by James Crethar on April 17, 2009 at 2:01 am
    Hi guys,
    I’m new here and I’m rendering a 20 minute video in Sony Vegas 7.0, and I get this error message:
    Sony Vegas 7.0
    Version 7.0e (Build 216)
    Exception 0xC0000005 (access violation) WRITE:0x8580 IP:0x6BAA32
    In Module ‘vegas70.exe’ at Address 0x400000 + 0x2BAA32
    Thread: ProgMan ID=0xE90 Stack=0x1AFF000-0x1B00000
    Registers:
    EAX=01aff4bc CS=001b EIP=006baa32 EFLGS=00210246
    EBX=3b0dac20 SS=0023 ESP=01aff430 EBP=01aff778
    ECX=00000020 DS=0023 ESI=01aff43c FS=003b
    EDX=01aff5b8 ES=0023 EDI=00008580 GS=0000
    Bytes at CS:EIP:
    006BAA32: F3 A5 8B 43 0C A8 05 74 …C…t
    006BAA3A: 0A 8D 54 24 0C 52 E8 B7 ..TR..
    Stack Dump:
    01AFF430: 3B0DAC20 3A910000 + 7CAC20
    01AFF434: 00000000
    01AFF438: 021F6DA8 020E0000 + 116DA8
    01AFF43C: 00000000
    01AFF440: 3FF00000 3FE40000 + C0000
    01AFF444: 00000000
    01AFF448: 00000000
    01AFF44C: 00000000
    01AFF450: 00000000
    01AFF454: 00000000
    01AFF458: 00000000
    01AFF45C: 00000000
    01AFF460: 00000000
    01AFF464: 00000000
    01AFF468: 3FF00000 3FE40000 + C0000
    01AFF46C: 00000000
    > 01AFF4BC: 006BAC5D 00400000 + 2BAC5D (vegas70.exe)
    01AFF4C0: 3B0DAC20 3A910000 + 7CAC20
    01AFF4C4: 01AFF528 01A00000 + FF528
    01AFF4C8: 3B0DABB8 3A910000 + 7CABB8
    01AFF4CC: 28C4DAC0 273D0000 + 187DAC0
    If anyone could tell me what the problem is or how to fix it, I’d really appreciate it 🙂
    Many thanks!
    Anne irene Johansen replied 17 years, 3 months ago 4 Members · 6 Replies
  • Steve Rhoden
    April 17, 2009 at 4:21 pm
    If you want a quick and effective solution, you need to
    provide more information like…
    What format is this 20 minute video you are rendering,
    And what format and codec are you selecting when rendering.
    And how long into the rendering process did this error
    popped up.
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Portfolio at:
    http://www.youtube.com/hentys
  • James Crethar
    April 21, 2009 at 1:35 am
    I am have imported HD .mod files (I changed the file extension to .mpg and rendered the video without and issues numerous times before) and there are some .mpeg video files in there too (I used a few different cameras for multi-angles).
    I am rendering in PAL DV Widescreen AVI (Audio: 48,000 Hz, 16 Bit, Stereo, PCM Uncompressed.
    Video: 25 fps, 720×576, Lower field first.)
    The thing is, I have selected particular parts of the video and rendered that region only to see if it’s a particular portion of the 20 minute video giving problems. Sometimes it renders 100%, sometimes 2%, sometimes 13%, there are other random % times it fails, but those are the most common.
    If you need additional information Steve, please let me know!
    Many thanks! 😀
  • Anne irene Johansen
    May 4, 2009 at 2:33 pm
    I’m sorry to say I can’t help you with your problem as I have the exact same problem myself. I’ve been working on finding a way to solve it for 2 days now. Have you found a way to solve it yet??? I get other error messages too though such as: Unknown error, not enough memory etc etc. The last one is bull ’cause I just deleted half of what’s on my computer (NOT the material used in the video I might add) and that can’t possibly be the problem.
    I have also tried rendering just parts of it and the same thing happens to me as you’re describing. Sometimes it works, sometimes it doesn’t. It’s really annoying as this is my best video yet, by far and I worked on it for almost 2 weeks. Now it’s all been just a big waste of time as it’s completely useless sitting on a timeline in Sony Vegas.
    I’m using Sony Vegas Movie Studio Platinum 9 btw.
    Never had this problem before and I’ve made a whole bunch of videos with it. I would’ve listed up for you what I’ve tried so far, but I’ve tried so many things I can’t even remember them all.
    Please let me know if you do find a way to solve this problem.
    Thank you,
    – A
  • James Crethar
    May 10, 2009 at 11:18 am
    I am sorry to hear that Anne, I know just how much frustration you have! I too spend all of my holidays (2 weeks flat) doing this video and it’s just gone to waste. I’ve tried everything you described too, to no avail.
    One question, whilst you were rendering the video earlier in the time you were making it, did it render perfectly fine? Because mine did, then at some point it started getting errors. Also, if you open a different window and go back into Vegas, does it not respond for about one minute before Vegas finally is usable again? I noticed that started happening around the same time error messages came up.
    Best of luck, and stay in touch!
    James Crethar
  • Mike Kujbida
    May 11, 2009 at 12:23 am
    [James Crethar] “Also, if you open a different window and go back into Vegas, does it not respond for about one minute before Vegas finally is usable again?”
    Options – Prefs – General – Close media files when not the active application.
    If this option is enabled, disable it and vice-versa.
    May 11, 2009 at 12:40 am
    I am so sorry I didn’t post this reply earlier. I went to the sony vegas website and read just about every Q&A on that site. Finally I found a tip that was useful. I wish I could just link you to it, but I’ll try to explain. (I’m from Norway so it’s not as easy)
    The mistake was quite simple actually. Too much stuff in my project. So, their tip was this: First, render just a small part. Even if it’s just a minute. Then, once you’ve done that click the “clear all unused media” button and render the next part. After that, click the “clear all unused media” button again. Continue this until you have all parts of your project rendered. Then clear everything and import what you have rendered. It takes some extra time and of course you’ll have to put the music back in there and all that (if you have that in your project) but in the end it’s worth it. It worked for me. I really hope this helps. If not, I’d recommend the website. I was completely shocked to discover how many pages of Q&A there were..
    Let me know if it works! Just remember to clear all the unused media between rendering. Very important!
