Activity › Forums › Adobe Encore DVD › error message in CS3
  • error message in CS3
    Posted by Larry Schutte on August 28, 2008 at 4:47 pm
    Again, since I had no response from the first post– After exporting a timeline from Premiere CS3 into Encore for a no-menu burn, I get a window that says- Encore has encountered an error SrcTime.Cpp-105. It goes away after two clicks and continues the burn but the DVD does not play in a regular dvd player. Upon closing Encore I get another window that says- An input contract violation has occured. In the project window the .wav file is always untranscoded. Other posts report the same problem? My system is working great on my HP Pavillion dv8000 with dual core Intel and 7200 rpm drives running XP Pro SP2. Help! Larry
    Larry Schutte replied 18 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
