Error message during MPEG-DVD export
I’m running Premiere Pro 1.5 on a Dell Precision 650 workstation with XP Pro and an internal Sony DRU-710A DVD burner. When I have finished creating my video and attempt to export it as an MPEG-DVD file using Premiere Pro’s Adobe Media system, the file appears to run correctly, then I get an error message that says “Adobe Failed to Return a Frame”. When I check the destination folder on my PC I can see both the WAV and AVI files, but the playback is just a black screen. This is the same no matter what setting I use in the Adobe Media creator. When I try to burn straight to a DVD using the Premiere Pro “Export to DVD” function I get an “Assembly Error” message and the burn stops. Any ideas?
