Activity Forums Panasonic Cameras Error Message
  • Error Message
    Posted by Tim Scarpino on November 28, 2005 at 5:57 pm
    I need some help.
    I think I tried to eject the cassette on a low battery, and now the DVX is giving me an error message:
    AUTO OFF UNLOADING LOCK
    The little red Cassette screen Icon has the circle/line through it and blinks, than the DVX shuts off after about a minute. There’s still a cassette in the unit.
    Any ideas?
    I’m comfortable removing the DVX cassette tray cover and such, what I’m wondering is does the DVX have a manual eject the way most ENG/EFP camcorders do, by turning something inside the threading compartment?
    Tim Scarpino.
    Tim Scarpino replied 20 years, 10 months ago 2 Members · 2 Replies
  • Noah Kadner
    November 28, 2005 at 6:44 pm
    That often means it’s time to send in for repair if the problem is not resolvable after replacing batteries, switching to VCR mode, etc. I would not recommend taking the cassette case apart- you would likely void your warranty if it did need further service.
    Noah
  • Tim Scarpino
    November 28, 2005 at 8:39 pm
    [Noah Kadner] “That often means it’s time to send in for repair if the problem is not resolvable after replacing batteries, switching to VCR mode, etc. I would not recommend taking the cassette case apart- you would likely void your warranty if it did need further service”
    Noah, thanks so much for your response and advice.
    At this point, I changed batteries, hit the Reset button, and was able to get the tape.
    I have not been able to work with my camera since then, but will tonight. If issues continue, I’ll contact my dealer.
    Thanks again.
    Tim
