Activity Forums Adobe Encore DVD Error Message
  • Error Message
    Posted by Cliff Elliott on January 12, 2008 at 11:32 am
    Hi all, I recently upgraded from Premiere Pro 2 to Premiere Pro CS3. This upgrade came with Encore CS3.
    I have always wanted to use Encore and finaly now have the chance.
    I decided to create a project to see how well the program worked and very quickly picked up how the software functions.
    After creating the project I ran a check from within the build window and all was well, I then instructed Encore to encode an ISO image file.
    It performed perfectly until the final part of the encoding when the program popped up a message stating there was an error at 01:11:37:24 I quickly realised this was a time code location and promtly checked the time line at the coordinates but coud not find a problem.
    As a test I then set about creating another project with all new video and menu files, with after a long wait during encoding the same error occured.
    Does any one have any ideas about this problem.
    Thanks, Cliff Elliott
    Mike Velte replied 18 years, 8 months ago 2 Members · 1 Reply
  • Mike Velte
    January 14, 2008 at 3:25 pm
    You may have hit Window’s 4gb file limit. Try building a Folder instead.
